Environment Locking - Acquire Lock action token issue
When trying to use the "Acquire Lock" action in "Environment Locking" Business object, A unique value is generated for the "Token" output parameter even though a preferred token value is given in the input parameter. This is happening only sometimes. otherwise, the input token value is generated as the output. Is this a known issue in v5? Please refer to the attached screenshot for Acquire Lock stage logs during normal behaviour and during the issue.
ArtemRatkevich
Hi, Sanjay. I have a similar problem with locking in v6. The reason for this behavior is unclear. I suppose that this situation occurs when the BP server freezes. It looks like a bug in blue prism.
