Error in Query using OLE DB
16-09-19 06:35 AM
I am using OLE DB connection in BluePrism.
I am trying to execute following Query:
"SELECT * DISTINCT [User ID ] FROM [Sheet1$]"
But it is throwing following error message:
Internal : Could not execute code stage because exception thrown by code stage: Syntax error (missing operator) in query expression '* DISTINCT [User ID ]'.
Please help me to solve this error.
Mohini Shelke
vElement It
16-09-19 11:17 AM
Saumitra Sharma
Consultant
EY
Indian/Christmas
16-09-19 11:39 AM
------Original Message------
Mohini, SQL Query is wrong it should be SELECT DISTINCT [User ID ] FROM [Sheet1$]...U can use either Distinct or * both not together
Saumitra Sharma
Consultant
EY
Indian/Christmas
16-09-19 11:47 AM
Select * from [Sheet1$]
16-09-19 01:31 PM
Thanks & Regards,
Mohini Shelke
RPA Developer, vElement IT,
U can use this but this will delete the duplicate data permanently only unique data will be there...delete dups from (select *, row_number() OVER ( partition by [User ID] order by [User ID]) as rn from [Sheet1$]) dups WHERE rn > 1
16-09-19 03:03 PM
There should be space between 1 and Select you have missed the space it should be rn > 1 Select * from [Sheet1$]
Saumitra Sharma
Consultant
EY
Indian/Christmas
16-09-19 06:42 PM
I tried with space also,still getting same error.
Mohini Shelke
vElement It
17-09-19 06:19 AM
Saumitra Sharma
Consultant
EY
Indian/Christmas
18-09-19 05:57 AM
Can you post your vbo here. Let me check.
Shashank Kumar
Singapore
+6581326707
18-09-19 10:51 AM
Thanks & Regards,
Mohini Shelke
Hi Mohini,
Shashank Kumar
Singapore
+6581326707
