Error java - Panel designed with Java Swing interface
29-11-18 04:58 PM
Hi!
I am trying to work with an application that shows some information of a table using a panel, when I try to read the table I get an error, please check the attached image for more information about the error.
What can I do to read the information contained in the table?
I have Java Access Bridge installed, and I have reached the developers and found out that the table is developed using Java Swing interface, or something similar
Can you please provide any help?
Thanks in advance
30-11-18 05:05 PM
Panel is not a table. Your table is likely ON that panel - check actual element tree and fix your element attributes in modeller.
You might also have some custom control, which is not supported by JAB.
