Error while using Notepad Business Object
AniruddhGovekar
I am undergoing foundation training in the blueprism rpa software. The process flow is
Start -> Launch::Notepad-> Close::Notepad -> End .  The application launches but fails to close and I get this error message - Internal : Failed to perform step 1 in Navigate Stage 'Terminate' on page 'Close' - Not Connected. What does this mean? How do i troubleshoot this problem. I am using blueprism 7.2.1.
Thanks,Aniruddh
Aniruddh Govekar
Best Answers
After launch try to use attach also and then see if it closes properly.
Thanks & Regards,
Technical Lead
Thanks & Regards,
Technical Lead
harish.m
Level 12
 Just to add you need to   make sure notepad launch successfully before closing the application.
 I would recommend to add wait stage after launching to verify notepad launched successfully before trying to close it.
Harish Mogulluri
Lead developer
America/New_York TX
Hi Tejas.. Thanks for your guidance. I created an attach page with a read object and now it works fine.
Aniruddh Govekar
Hi Harish. That is a great suggestion. I'll keep it in mind.
Aniruddh Govekar
