Execution of blueprism process through CTM
Vikram.R
I using Control -M to execute a process as per the customer requirement the process take 2min to complete the process but sometimes more than 2min. But control-M logout after 2min, So need help how to set CTM to execute logout on completion of blueprism process.
Can anyone please help me on this
Its really important
Vikram Ramesh
Hi, Vikram,
honestly, I do not fully understand what you described. Let me ask you a few clarification questions.
You are saying that that pressing keys Ctrl "dash" M starts Blue Prism process? Can you explain it as Blue Prism process is usually started from within Control Room. What does it mean when you write - control-M logout after 2 minutes? Who presses Control-M why it is causing logout?
When you explain us better your issue we will be in better position to suggest some meaningful solution.
Zdenek
Zdeněk Kabátek
Head of Professional Services
NEOOPS
http://www.neoops.com/
Europe/Prague
