Exposing a Process as a WebService using HTTPS
MohammedNissarK
Team,
Our requirement is to expose a process over https and that has to be shared with external team to invoke the service and it has to add work queue items based on the inputs that we have exposed in the startup parameters. This is easily achievable with http but we want https for the wsdl url so could someone help with how to configure ssl certificate to achieve this https wsdl? Do we need to install ssl certificate only in runtime machine or configure the app server connection mode with WCF: SOAP with Transport Encryption as well
Mohammed Nissar Kaja Mydhin
Hi Mohammed,
You need to configure your runtime resource with local certificate to secure the network connectivity. Refer the attached document for the detailed steps to setup the secured network.
Athiban Mahamathi - https://www.linkedin.com/in/athiban-mahamathi-544a008b/
Technical Consultant,
SimplifyNext PTE LTD,
Singapore
