External WebService - Input Parameter (Deep structure)
KonstantinosVog
Hello, I am trying to consume an external webservice from Blue Prism. 1. I have set the Webservice using its WSDL 2. Inside the Object Studio I created an action choosing the operation of the WS that I want to consume The problem is that the operation that I want to execute, has a deep structure in the input parameters.  For that reason in the Action stage inside Blue Prism the input parameter has 'Unknown' type. I tried to create a hardcoded Data Item with the deep structure filled, but the service call doesn't return results. Have you ever experienced something similar before? Having a deep structure in the input parameters of a WS and how to populate it? Thanks in advance. Konstantinos
KonstantinosVog
Any ideas? Konstantinos
MadsMeyer
Hi k.vogiatzakis. Did you find an answer to your question? I am looking into the same issue at my end.  Best regards,
