Focus not working for Java automation
SanjayKumar2
Hi all,
We are working on Java automation for Oracle. we are getting scroll bar in one of the page and Focus is not working to scroll down.
Ideally we use Focus to make sure focus on the element and click but in this case it is not working, Any suggestions will be very helpful.
Thanks in advance.
Sanjay Kumar
Manager
SLK Software
InJoeKhor
Hi Sanjay,
Have you confirmed you have JAB installed correctly?
The Java Access Bridge (JAB) is used to enable Blue Prism to interface with Java applications. The Java Access Bridge is a technology that exposes accessibility information about Java applications and applets to external applications such as Blue Prism.
There is an article in the knowledgebase about installing the JAB files manually: https://blueprism.knowledgeowl.com/help/manual-jab-installation, You want to make sure you have the basic installation done correctly before getting it to interact with Blue Prism.
You may want to read the Java Automation Guide on the Blue Prism Portal. It contains hints and tips when interfacing with Java applications.  Here is the Java bridge Access pdf for your reference: https://portal.blueprism.com/system/files/2017-11/v6 User Guide - Java Access Bridge.pdf
In Joe Khor
Sr. Product Consultant
In Joe Khor Sr. Product Consultant Blue Prism
