We are using VCI with Citrix without any issues.
The issue is mainly caused when Blue Prism tries to ask the operating system for the current foreground window token. The Windows operating system keeps a track of which window currently has the token which designates it as the current foregrounded window. So when the call to Activate Application action is made, Blue Prism asks the OS for this token. Due to the way various applications respond to such requests, or the permission levels for eg on VMs or bitness, Blue Prism is prevented from getting this token. Hence Blue Prism tells you it could not identify the current foreground process window that owns this token.
The solution is
- Use "Verify" or "Focus" actions on the application instead of "Activate Application". This highlights the application that you want to foreground.
- Make the application run mode to Foreground
Hope this helps
Walter Koller
Solution Manager
Europe/Vienna
