Global Send Keys and Send Key Events
KaliRaj
WWhat is the Global Send Keys and Send Key Events ? Why we need Global Send Keys and Send Key Events ? When we have to use Global Send Keys and Send Key Events ? How to Implement Global Send Keys and Send Key Events ? Please give Real Time Usage Global Send Keys and Send Key Events with examples
MetVonghiran
Hello, Kali__Raj In the document tap, if you type ""key"" in the Search Documents textbox, you will find a document called ""Guide to Send Keys and Send Key Events"". You should find all of your answer from there.   Regards, Met Vonghiran
