Help: Error running tesseract - read_params_file
NicholasD_Agost
I have recently received the follow error while running an object that uses the "Read Text with OCR" functionality: "Error running tesseract - read_params_file: Can't open C:\Users\***************\AppData\Local\Temp\e14g5fg0.kpt"
Has anyone run into a similar error and what did you do to fix it?
Thank you for any assistance with this.
Nicholas D'Agostino
BenLyons
Hi Nicholas,
I have seen this before and it was due to the temp folder effectively being "full". Try deleting everything you have permission to in that folder, empty the trash and give it a reboot.
If that works, you can add a stage during your process clean up actions to delete similar files.
let me know if that works.
Ben Lyons
Product Consultant
UK
