Hi Leena!
You can use the Attach action, available for your application, to ensure that the application enables the model and highlight option.
This example performs the attach in Chrome, but it is very similar for the other applications, the attach will only work if the application is not connected.
After attaching, check again if the application modeler option is still disabled.
Lucas Silva
