How do you iteratively click similar buttons on a page?
kevin_b_hall
Hi, To practice, I wanted to make a simple Blue Prism process that clicked each "Unfollow" button on a twitter page. I thought I could do this by looking at the path of an element and iterating the number that identified the "Unfollow" button but I can't figure out how to do this. For example let's say the first "Unfollow" button had the path value of "/HTML/BODY(1)/DIV(2)/DIV(1)" and the second had "/HTML/BODY(1)/DIV(2)/DIV(2)". Is there a way to put a variable within the path and use a counter to iterate through each button? Kind of like the following psuedocode? Counter = 1 UnfollowButtonPath = "/HTML/BODY(1)/DIV(2)/DIV({Counter})" UnfollowButtonCount = 300 Loop UnfollowButtonCount times { Click UnfollowButton with Path == UnfollowButtonPath Counter + 1 } Or is there no way to dynamically change an element or have some kind of pattern recognition?
GongquanZHANG
This is also my question. Any way to solve these kind of issue?
JoakimEklund
In application modeller you can set the path attribute to dynamic, thus enabling you to enter ""/HTML/BODY(1)/DIV(2)/DIV("" & {Counter} & "")"" within the navigate stage you use to click the button.
Thanks joakimeklund! After changing the element's Path to be dynamic (was not aware of this option) I was able to change the Parameter for Path in the Navigate action to change the text to be whatever I wanted and iterated through. Worked perfectly!
