How to Create Text Fie Using BluePrism
MohiniShelke
Hello All,
Anyone knows how to create Text File in BluePrism?
In Utility-File Management, there is  a option to Create Directory but not file?
Thanks in Advance
Mohini Shelke
vElement It
The action 'Write Text File' will create the file if it does not exist already. And then you can add text to that text file with the action 'Append to Text File'.
Dave Morris
3Ci @ Southern Company
Atlanta, GA
Dave Morris
Atlanta, GA
Just to add you can create TXT as well as CSV file using same.
