How to change destination path of exported process in CMD?
Im using this automatec command in CMD to export my process from the database: automatec /export "my process" /sso It exports the process to Blue Prism installation folder. I wonder is it possible to change the destination path, to save it, on the Desktop for example. If yes, how do I do it?
Create a batch file and save it in the target folder.
vivek.kumar.goel
I created the batch file and when I run it manually, it stores in target folder. However, when I try to run the bat file from the start process action of utility environment, it gives me the same problem. Any help?
EstebanCarrasco
Could someone solve this? I'm having a problem running the bat from blue prism. I need to know how to give my destination folder in the automatec command.
Try this code stage
