How to configure two process to work on same queue
Vikas
Hi, How to configure step by step two process utilising single queueTIA
5 REPLIES 5
There is nothing to configure, different processes can share the same queue. If you want process A to work certain types of item and process B to work another type, then you need to think about how to distinguish item types. Applying tags is usually a good way to achieve this.
NarayanShrawagi
I even tried this and it works fine as John said,. Please post here if you face any issues
Narayan
NarayanShrawagi
Narayan
Thank you john.i will try that.
how to get BP software to learn indipendently . thanks Subra
