How to consume REST API with token based authentication in BP
06-07-18 03:33 PM
Hi Team,
We are on 5.0, we need to consume REST API which follow token based authentication .
Our aim is to get excel file using it.
Reg
Srikanth
29-04-22 04:13 PM
Hi Srikanth,
This is definitely something that can be done, please can you let me know what API and the type of token authentication you will need (1 step or 2 step oauth).
It may be that you can get the bearer token from the application and store this in your credentials that the WebAPI uses as authentication for every call.
Best Regards,
Ronan Considine
Senior Business Analyst
Best Regards,
Ronan Considine
Ronan Considine
