How to generate ta GUID using BluePrism
05-04-18 07:00 PM
I want to work with SQL database where I want to generate GUID and save into sql database.Please help me in this
05-04-18 07:19 PM
Research the SQL data type 'uniqueidentifier' or use a code stage with a line such as OutputText = Guid.NewGuid()
05-04-18 08:22 PM
In Utility - Strings object you have Generate New GUID method.
