How to get a shortcut's target path
MengYu
How to get this by coding? Or any other method? Is it right to spy in windows/folder/file properties?
KaiSchlüter
Hey Karl.Yu, if i understand correctly: A target path of for example a shortcut can be found by: SHIFT+Right Click. An extended menu will open with the option ""Copy As Path"". You can Spy in Windows/Folder but check the built in VBO - File Management. Maybe that already solves some of your development problems.  Regards
MengYu
Hi kschluter, Thank you for your comment. I've checked come designs in File Management, some can get path from a file but not for shortcut's target path. ""Copy As Path"" also can get the shortcut's path, but not the target path. I tried spy in windows but stuck in the stage after right click. It need another object to spy on the right click dialogue box, but I don't know the window title of it. Any ideas on it? Also it will be great if any advice on coding. Regards.
diggs
I would put my money on some 3rd party application, try one of the ones on this list for example:   https://www.raymond.cc/blog/parse-and-analyze-windows-lnk-shortcut-file…
