How to get window title using spy mode
BasavarajMudlap
Hi BP team,
Facing the problem in getting the sub window title used all kind of spy modes.
Flow as follows.
Click on main window page ->Chosen Apps Menu->Selected Sub window opens (It is separate page).
It is window based application navigate to the sub window from main window. I need to fetch the sub window title.
In wait stage I need to put the condition as sub page opened & it is pass the result.
In attributes list I checked enabling unique element but it is not matching the query.
Seeking your inputs.
Basavaraj
james.man
It's pretty difficult to help without having access to the application itself.  Do you have a screen capture or name of the application if it's publicly available?
One thing you could try is to see if the "sub window title" can be found from the application navigators, which will list out every spyable element the application has. https://bpdocs.blueprism.com/bp-6-9/en-us/uia-navigator-form.html
James Man
Professional Services
Asia/Hong_Kong
James Man,
let me try and get back to you.
Thanks.
Basavaraj Mudlapur
[email protected]
