How to search environment variables starting from fixed string in process
NehaOza
I am looking any VBO to search environment variable through wild card character like below
I am creating EOD report as shared process, which takes from, to, process name as start up parameters.
In process based on process name input parameter passed, find Environment Variables related to that process
Lets say,
Process Name : MyProcess
Environment Variables present:
MyProcess_FileName
MyProcess_FilePath
In process, search EV starting from "MyProcess_*"
Is there any way to do this through existing VBO or any other way
Neha
Hi Neha,
As far as I know, there is no VBO built which can do that for you and also you can't access the list of environment variables from Command Line where you can only create and delete the environment variable.
But I can suggest that if you have the access to the back end database SQL Server, then you can create a custom business object or a process which can use the SQL Server VBO and try to use the following query:
SELECT [name]FROM [Blue Prism].[dbo].[BPAEnvironmentVar]WHERE [name] LIKE '%MyProcess_%'
This query will fetch the names from the BPAEnvironmentVar table which can retrieve all the process names for you. Below is a sample query snippet for your reference.
Website: https://devneet.github.io/
Email: [email protected]
PabloSarabia
Level 11
Hi!
As Devneet said, its easy if you have access to the DataBase to execute a Query and get the info.
Another way, if you don't have access to the Database server directly is to use the "Advanced Find" window or "Explore Dependencies" one.
Here you have all the Environment Variables that you have referenced in your process:
(you can find this from the "edit" menu in each Process or Object)
See you in the community, bye 🙂
