How to spy java applet applications?
pallshan
Hi All, I am trying to automate java applet based application, but I am not able to spy.Can anyone guide me to proceed. Thank you.
5 REPLIES 5
pallshan
After restarting blue prism I am not getting that error pop-up as i mentioned before. Now I am able to spy the objects using java mode but I am not able to enter the values into it. I am getting following error even if I am using JRE 1.8:- ""Internal : Failed to perform step 1 in Write Stage 'login' on page 'Action 1' - Call to setTextContents failed"". I have used write tool to enter the values into the spied objects and stored the values in data items. Please help me solve this issue.
Have you gone through the Java Automation Guide on the portal and tried all the options mentioned within it. For what you are describing it might be worth experimenting with the decendtree and/or ignorenotshowing Application Wizard Options mentioned in the guide.
pallshan
Yes I am referring that java automation guide and I am able to enter the values using send keys.
It might be worth installing and experimenting with some of Suns Java Access Testing tools (called Java Ferret and Java Monkey). According to the information on this web site you may be able to download the testing tools with JAB version 2.0.2: http://docs.oracle.com/javase/7/docs/technotes/guides/access/enable_and If Suns own JAB testing tools cannot identify anything within your Java applictation it would indicate an issue with your installation of Java access bridge has a problem rather than an issue with the Blue Prism tool. If that is the case I would point you towards some of the problemen solving articles in the Knowledgebase (a different version or a manual install of JAB may be required).
SaurabhJaiswal
Unexpected Error Stack empty error is there in the Java automation,, Help to resolve it
