How to stop the Bot in schedule using Requeststop
Is there any way to stop the bot in schedule using Request Stop ?
The Request Stop feature only works for Sessions that are running Processes that regularly call the IsStopRequested() function and use a decision stage to determine whether the output is True or False. The 'True' path is the one that should then proceed to shut down the Session. If the Process doesn't have this function build in, then your only course is to use Immediate Stop.
