I am facing issue in double click in AA mode.
dhavaljp
I want to use double click and its not available in AA mode so I try with global mouse click ,I try with pause and activate application before using global mouse click center. still its not working.
John.Pass
Hi Dhaval,
How do you have the double click event setup?
Are you using 2 separate global mouse click centre actions in the same navigate stage?
What type of element are you trying to double click?
John Pass
Senior Customer Support Analyst
John Pass Customer Support Analyst Blue Prism
_Amlansahoo
Level 11
Hi Dhaval,
Blue prism is not providing double click option for AA and UIA mode. I have put this on idea in portal and several tickets but no luck yet.
Amlan Sahoo
RPA Consultant
Equinix
Amlan Sahoo
maneesh.vemula1
- Have you tried just using 'global mouse click center' action back to back in order to create a double click effect. This would only be possible if the automation is able to recognize the element quickly.
- I am not sure what element or application you are trying to spy but have you tried spying in Browser Mode?
Maneesh Vemula
Philadelphia
