In 7.2, Runtime resource is showing state as Idle but connection is disconnected.
Sheela
We are planning to upgrade BP to 7.2. So while testing, we tried to setup Runtime resource.
The state of resource is Idle, but connection is disconnected.
Appreciate any suggestions to resolve this issue.
Sheela Parthasarathy
Assistant Vice President
Deutsche Bank Group
Pacific/Apia
13 REPLIES 13
Mukeshh_k
Hi @Sheela Parthasarathy - Check this thread out - https://community.blueprism.com/communities/community-home/digestviewer/viewthread?MessageKey=12ecdfd9-3da0-4598-9f29-3fa2d81881de&CommunityKey=0eb42ccc-db4b-4048-b061-c3608dc3d713&tab=digestviewer
Mukesh Kumar
Hi Mukesh,
Thank you for the suggestion.
But restart didn't work.
Getting below error
BluePrism.AutomateAppCore.TcpTalker Talker[XXX.XXX.XX.XXX:8181] Error connecting to resource BluePrism.Server.Domain.Models.BluePrismException: Connection to the resource timed out. at BluePrism.Core.Utility.IPv6TcpClientFactory.CreateTcpClient(String hostname, Int32 port, String localResourceName) at BluePrism.AutomateAppCore.TcpTalker.Connect(String sResourceName, String& sErr)
Deutsche Bank Group
Pacific/Apia
Hi @Sheela Parthasarathy - Probably this might be helpful as its exactly the same issue that you are facing - https://community.blueprism.com/communities/community-home/digestviewer/viewthread?MessageKey=210a17db-909e-4a23-a73a-480af3f29d2a&CommunityKey=0eb42ccc-db4b-4048-b061-c3608dc3d713&tab=digestviewer#bm...
If not - I would recommend to involve IT or in parallel raise a Support Ticket  - https://support.blueprism.com/en/support/login or an email to support@blueprism.com / for Blueprism Cloud - Cloud Support <cloudsupport@blueprism.com>
Mukesh Kumar
Hi, Sheela,
not sure if this can be the reason but recently we installed Blue Prism in the environment without DNS server and we had to add IP address of BP App Server to  Runtime Resources hosts file. In Control Room the RR were Idle, disconnected and strange icon which I have never seen before. Updating hosts file fixed everything.
I am not sure if this is your case but you can give it a try.
Zdenek
Zdeněk Kabátek
Head of Professional Services
NEOOPS
http://www.neoops.com/
Europe/Prague
@Zdeněk Kabátek
Could you please provide the exact steps of updating the host file, which fixed your issue.
We will try the same. Thanks
Sheela
Deutsche Bank Group
Pacific/Apia
Hi, Sheela,
you need to go to your RR to the path c:\Windows\System32\drivers\etc\ and locate file called hosts.
In this file you need to add a line something like this (I made the ip address up so you need to enter the correct one):
192.168.10.15    <fqdn of your BP APP Server>
Then save hosts file in the same location and clear cache and give it another try.
Zdenek
Zdeněk Kabátek
NEOOPS
Europe/Prague
bclayton1896
We're on 7.1 and sometimes see the idle disco state.
We have found running
"ipconfig /renew" and then "ipconfig /flushdns" followed by a restart has fixed this for us in the past.
Is the RTR a VDI?
Brian Clayton
Applications Consultant
The Auto Club Group
America/Dearborn MI
313-336-1896
Hi @Brian Clayton
Thank you for your suggestions.
We will try this solution.
We are using VDI as RR.
Deutsche Bank Group
Pacific/Apia
Hello @Sheela Parthasarathy, you are welcome. Hopefully, this helped your situation or at least opened further pathways of discovery.
Brian Clayton
The Auto Club Group
America/Dearborn MI
