I am trying to track down where I can download the internal objects/VBOs from, as for some reason, when I installed Blue Prism, none of them are there...
Any guidance is appreciated
Kind Regards
I would advise you to check the typical Blue Prism installation folder C:\Program Files\Blue Prism Limited\Blue Prism Automate\VBO and if there are any XML Documents there, import these.
Best,
Gert
