Integrate Abby Flexi Capture engine with Blue Prism
SankarlalM
How to Integrate Abby Flexi Capture engine with Blue Prism? How we can use Flexi capture engine to extract data from the Semi-Structured PDF Documents? Is there any reference material is available?
ashish.easow
Abby integration with BP is available via a VBO but its not available for download from the portal. If you are a partner/client you can reach out to the BP DEM or Account manager and they should be able to direct you to Abby Partner Manager on in Blue Prism, who should be able to help you put. regards Ashish
