Ocr performed - ready for Capture - Docment struck
KrishnaElapavul
Hi
I have updated Decipher from 1.2 to 2.1. and  existing BP ver is 7.0
  • All services are running fine
  • I am able to push the  doc to Decipher
  • Image process and  OCR  stage competed successfully
  • BUT Document not moving to further stage   and struck  at capture
Can some one  please advise what could be the issue ? I  have verified all logs but not able to observe any error message.
I see DEBUG statement in a Image process log  as below and feel it is ok
2022-07-21 18:47:25.0041 [3308-1] DEBUG | SDK: Smart OCR SDK - Version: 3.9.21.09200, Branch: RC, User: Nuri, Compiled at: Sep 20 2021, 10:42:41
2022-07-21 18:47:25.0197 [3308-1] DEBUG | SDK: Calling OCR Document init for language: English
2022-07-21 18:47:25.0197 [3308-1] DEBUG | SDK: Loading external primary recognition engine...
2022-07-21 18:47:25.0197 [3308-1] DEBUG | SDK: Failed loading of requested external engine: 1, Fail reason: External engine plugin not initialized.
2022-07-21 18:47:25.0197 [3308-1] DEBUG | SDK: Initiated fall back to other external engines...
2022-07-21 18:47:25.0509 [3308-1] DEBUG | SDK: Successful fall back to engine: 5
2022-07-21 18:47:25.0666 [3308-1] DEBUG | SDK: External engine loaded. Engine code: 5
2022-07-21 18:47:25.0666 [3308-1] DEBUG | SDK: Init Swap Manager...
2022-07-21 18:47:25.0666 [3308-1] DEBUG | SDK: Prepare available languages...
2022-07-21 18:47:25.1759 [3308-1] DEBUG | SDK: External engine in use. Skip font loading.
2022-07-21 18:47:25.2072 [3308-1] DEBUG | SDK: Init Success
2022-07-21 18:47:26.0353 [3308-1] DEBUG | SDK: Loading user dictionary...
2022-07-21 18:47:26.5041 [3308-1] DEBUG | SDK: Init PDF loader
2022-07-21 18:47:26.6760 [3308-1] DEBUG | SDK: Register PDF loader events
2022-07-21 18:47:26.7229 [3308-1] DEBUG | SDK: Init external recognizer
2022-07-21 18:47:26.9260 [3308-1] DEBUG | SDK: Secondary OCR language: eng
2022-07-21 18:47:26.9573 [3308-1] DEBUG | SDK: External recognizer successfully initialized
2022-07-21 18:47:27.1135 [3308-1] DEBUG | SDK: Init barcode recognizer...
2022-07-21 18:47:27.2229 [3308-1] DEBUG | SDK: Barcode recognizer failed to initialize
2022-07-21 18:47:27.2854 [3308-1] DEBUG | SDK: Init ICR engine...
2022-07-21 18:47:27.3166 [3308-1] DEBUG | SDK: ICR engine successfully initialized
Krishna Elapavuluri RPA Solution Lead
TEchnology Consultant
DXC.technology
Ben.Lyons1
Hi Krishna,
It might be because of one of the following:
- User details for the capture client. If the user assigned to the Capture client (generaluser by default) has been changed, the credentials would need to be checked in both the UI and config file. The passwords may not be in sync.
- Or it could be that the Batch Type has been assigned to specific users or user groups and the Capture client hasn't been included. All the users set up for the Decipher Clients, will need to be selected to be able to access and process the batch.
If it doesn't sound like either of these, I would recommend raising a support ticket.
Ben Lyons
UK based
Ben Lyons
SS&C Blue Prism
UK based
Thanks Ben for your reply
I have noticed that the somehow log path entry  missed in  DataCaptureclientconfig, after adding it worked and see docs are processing
Krishna
SKF
DXC Technology
T +91 99000 63042
Krishna-mohan.elapavuluri@dxc.com
DXC.com | Twitter* | Facebook* | LinkedIn* | Campaign Promotion*
Planned Leave:
Company Holidays:
DXC Technology India Private Limited - 9th Floor, Block-D Littlewood Tower, TRIL Info Park Ramanujan IT City, Rajiv Gandhi Salai, Taramani, Chennai - 600113. CIN: U72900TN2015FTC102489.
DXC Technology Company -- This message is transmitted to you by or on behalf of DXC Technology Company or one of its affiliates. It is intended exclusively for the addressee. The substance of this message, along with any attachments, may contain proprietary, confidential or privileged information or information that is otherwise legally exempt from disclosure. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient of this message, you are not authorized to read, print, retain, copy or disseminate any part of this message. If you have received this message in error, please destroy and delete all copies and notify the sender by return e-mail. Regardless of content, this e-mail shall not operate to bind DXC Technology Company or any of its affiliates to any order or other contract unless pursuant to explicit written agreement or government initiative expressly permitting the use of e-mail for such purpose.
Hi !
How are you ?
How did you check the DataCaptureclientconfig please ?
Guilherme Morandini
Consultant RPA
Avanade Brazil
São José dos Campos
+5512981637307
Hi Guilherme.
The file that Krishna is talking about can be found in "C:\Program Files (x86)\Blue Prism\Decipher Automated Clients" (assuming you used the default installation. The specific file is called "SsiDataCaptureClient.exe.config".
jack
Jack Look
Sr Product Consultant
