VMware and PCoIP
l.kiciak
Hi, have any of you use VMware Horizon Client to connect to VDI? I can use only PCoIP, but haven't found any reliable information, whether it's possible to use that for BP remote access. I appreciate any bit of advise. Best regards, L
ashish.easow
My 2 cents , ones which I know are supported are -  VMWare vSphere, Tivoli Remote Control, Bomgar, VNC, DameWare, VMWare Console, PCAnywhere, NetSupport, but I'm not sure of horizon client. The tool used should not interrupt/disconnect or interfere in any way with the existing session running on the machines which is doing the work.
