Hi Mayank,
If you are using version of Blue Prism before 7.0, you can probably use SOAP request to trigger your process via API. I have a sample use case on a chatbot integration on my YouTube channel where I have showcased step by step how you can make an API call to trigger a simple process from a Flask server it will give you some idea:
Google Dialog Flow Chatbot Integration With Blue PrismLet me know in case you have any questions.
----------------------------------Hope it helps you out and if my solution resolves your query, then please mark it as the 'Best Answer' so that the others members in the community having similar problem statement can track the answer easily in futureRegards,Devneet MohantyIntelligent Process Automation Consultant | Sr. Consultant - Automation Developer,Wonderbotz India Pvt. Ltd.Blue Prism Community MVP | Blue Prism 7x Certified ProfessionalWebsite: https://devneet.github.io/Email: [email protected]----------------------------------
