Is there a way to get the logs of when resource level logging was done from system tab
11-03-22 05:00 PM
Is there a way to get the logs of when resource level logging was turned on/off from system tab?
I mean from any DB table can i get history when resource level logging was turned on/off at which date time etc.
Thanks & Regards,
Tejaskumar Darji
Thanks & Regards,
Tejaskumar Darji
14-03-22 09:15 AM
Hi Tejaskumar - I don't think it's timestamped anywhere. I thought it might be in BPAAuditEvents but after a quick test I found it's not. The setting is record in BPAResource.diagnostics:
1 = Override log inhibit on key stage types
2 = Override log inhibit on all stage types
4 = Log memory information
8 = Force garbage collection when collection memory info
16 = Log Web Service communication
32 = Override log inhibit to only show errors
John Carter
Professional Services
John Carter
14-03-22 01:37 PM
Oh ok got it. So no way to get change log.
Thanks for quick check John.
Thanks & Regards,
Tejaskumar Darji
Thanks & Regards,
Tejaskumar Darji
