Issue with Running MapieX
VaibhavGupta1
I am unable to run Mapiex on a machine. I have followed all the steps mentioned in the release notes.   Error: Failed to initialise MAPIEx (A MAPI Error occurred : 0x80004005 : MAPI_E_CALL_FAILED)
7 REPLIES 7
VaibhavGupta1
I am running this on Outlook 2010 - 32 bit version.
VaibhavGupta1
I am also using BluePrism 6.2.1
EricLiu
Missing dll? You have to install MapieX and there will be some dll files to copy into the main folder.
AmiBarrett
Level 12
Alternatively, switch to the Outlook VBO or using SMTP. Both are significantly more reliable than MAPIEx.
VaibhavGupta1
I did copy the files to the destination folder.
StephenConnoll1
You must link the dlls to the object on top of putting it in the folder.   Go to the initialise action for MapieX and go to the Code Options - you'll probably have to manually link it
VaibhavGupta1
Yes i have linked the copied DLL file in the initialise section as well. Would you know why does this error occur? Â
