Issue with screen resolution
AmitPatnaik
How to change screen resolution in blue prism. Most of the letters are overlapping with each other. PFA   Thanks, Amit
AmitPatnaik
Windows 7 : Control Panel\Appearance and Personalization\Display choose smaller 100% checkbox
6 REPLIES 6
It's the Windows desktop zoom setting - looks like you have it at 125%
AmitPatnaik
Thanks John It solved the problem.
Sankar_GaneshKo
How to adjust the windows zoom setting. How you fixed this issue.
AmitPatnaik
HubertAmbales1
what is the recommended screen size
There's no recommended screen size, use whatever works for you and your applications. As above, use 100% zoom and it's best to use a common screen resolution across all machines in dev, test and prod.
