Issues with Auto-Archiving of logs
30-09-21 04:20 PM
I had set up the auto archiving feature for the logs on the Production server, which was working fine for the initial few days. But later on, archiving is not happening as per the set timeline. I have the setting to archive the logs older than 3 months, but there are no logs archived since last 6 months. Has anyone faced this issue?
01-10-21 08:06 AM
Hi Sinduja,
I would recommend to log a ticket with support as likely your DB might have large session logs causing timing out issues.
Support can provide you with special DB scripts to handle such issues....
Take note your DBA must regularly perform maintenance to the Tables.
03-10-21 12:20 PM
Is the resource pc which is responsible for archiving is offline or constantly busy ? Then it can't do the archiving as archiving is performed by the resource PC you nominated when you configured auto-archiving.
Vipul Tiwari
Amazon
