Java Automation
28-02-19 05:14 PM
Hi
I am unable to spy some elements in Java Mode . I have enabled the Java Access Bridge and also installed JRE 8 . Only elements i can spy is buttons and all the menu items not getting spied. Can anyone please help me in identifying the issue with Java mode.
Kalyan
28-02-19 10:09 PM
How did you enable the bridge? Was it via Blue Prism's JAB installer, or did you use the CLI command for it built into JRE8?
01-03-19 12:00 PM
Hi
I have enabled the bridge from Control Panel\All Control Panel Items\Ease of Access Center\Use the computer without a display\Enable Java Access Bridge
Kalyan
01-03-19 08:02 PM
Depending on the application and how it's coded, there could be elements overlaying the ones you're trying to interact with. There should be a sub-item on the identify button that says 'Open Application Navigator'. Does it show up in there?
04-03-19 03:26 PM
Yes, the ""Open Application Navigator"" shows up but BP is not able to load the elements, it says ""An error occurred retrieving the application model
Kalyan
