Java application : Not able to read the text of the combo box
10-11-21 06:39 PM
Hi ,
Unable to read the combo box text in java application. I've tried using get text, get selected text, but no luck .
Is there any resolution for it using Java mode itself ?
For now I have used region mode and applied relative coordinates to read the value of the combo box .
Thank you in advance!
THAKUR RANVEER SINGH
RPA DEVELOPER
Asia/Hyderabad
9849000203
RPA DEVELOPER
Asia/Hyderabad
9849000203
14-11-21 03:50 PM
Hi Ranver, Similar issue i have faced on Java application where i wasn't able to click/extract from a particular element and ended up using region mode.
Not sure if it is with java application or java mode's limitation.
MuraliKrishna
Senior Consultant - Automation Developer
MuraliKrishna
