Hi Yashaswini,
The following query can help you to get the number of sessions being run on any particular date and for any particular process:
SELECT B.[name] AS process_name, COUNT(A.[processid]) AS session_count FROM [Blue Prism].[dbo].[BPASession] A INNER JOIN [Blue Prism].[dbo].[BPAProcess] BON A.processid = B.processidWHERE CAST(A.[startdatetime] AS DATE) = '<DATE_VALUE>' AND B.name = '<PROCESS_NAME>'GROUP BY B.[name]
Substitute the highlighted text as per your requirement. Below is a sample query being run:
Hope it helps you and if it resolves your query please mark it as the best answer so that others having the same problem can track the answer easily
Website:
https://devneet.github.io/Email:
[email protected]----------------------------------
