Lock Item base on Item ID
MateuszBartczak
I need to use Set Data action on specific pending items. Is there any way to lock item in BP queue based on the Item ID?
Thanks.
Mateusz Bartczak
In v6.7 a Get Item by ID action was introduced but I'm guessing you're not on that version. Using the item key with Get Next Item is the next best option to lock the item you want. Tags are also an option but make sure you don't tag unique values (it will lead to DB trouble later).
John Carter
Professional Services
(for version 6.7)Will that return worked items as well ? will that item be in locked status once we get it using item id ?
Ishan Mahajan
India
