Login Agent Issue
06-03-19 12:43 AM
21-05-19 12:46 PM
23-04-20 01:17 AM
Hi Ami Barrett,
I work on an environment which demands me to use RDP. I cannot see the txt file you mentioned before, would you mind re-attaching it please?
Also, I'm using Blue prism 6.71 and successfully configured the application server and resource PCs. I'm able to run tasks on the resource PCs as long as I run the logout process from login agent, login again, and then run the tasks. The reason of this is because the only way available for connecting to the resource PCs is RDP. If I try to run processes without running the login agent - logout process, I get the following error:
ERROR: Internal : Failed to perform step 1 in Navigate Stage 'Calc' on page 'Test calc' - Could not identify process owning the current foreground window
What will be your recommendation??? I've thought adding a Task from Windows Task Scheduler to logout after a user closes the RDP session, I'm not sure it will be a good Idea though.
Thank you.
David Vizcaíno
RPA Programmer
EY
America/Bogota
- « Previous
- 1
- 2
- Next »
