Login Agent Runtime Resource Issue
SushmaRajolli
Hi Team,
I am facing an issue while working with login agent. After scheduling Logout process the process is locking the system but the BP runtime resource is getting close due to which login process is not working.
Please find the login agent server config info:
<?xml version="1.0" encoding="utf-8"?>
<configuration>
<workingdirectory path="C:\Program Files\Blue Prism Limited\Blue Prism Automate\"/>
<startuparguments>
<argument name="resourcepc"/>
<argument name="public"/>
<argument name="port">
<value>8181</value>
</argument>
<argument name="dbconname">
<value>Blueprism7</value>
</argument>
<argument name="sso"/>
</startuparguments>
</configuration>
What need to be done to keep Blue Prism Runtime Resource Instance Active.
Process is working when we need to lock the system but it's not working for login because blue prism instance is closing.
Can anyone please help me on this issue
Sushma Rajolli
9 REPLIES 9
LucasSilva
One option is to use the windows task scheduler to start the blue prism service, when you log out and also log in and any other action that may disable the runtime.
So as a trigger for the action you could have "When logging out" and as an action start the program "C:\BluePrism\BP.vbs".
If you have difficulties scheduling the task let me know.
Lucas Silva
Thank you for the response.
I have created batch file to create instance of blue prism and create a windows task scheduler as you mentioned but while using sign out from login agent it is not scheduling the window task scheduler when the screen is being locked
can you please help me on this setting
Sushma Rajolli
Hi Rajolli
Do you mean Windows log out by "sign out from the login agent"?
In my understanding, one possible scenario would be like this:
1. If the Login Agent is installed properly, the "Login Agent Service" will be running when the system is on --> Check the Windows Service and find "Login Agent Service".
2. When Windows is logged out and thereby Blue Prism runtime resource is closed, the Login Agent Service will invoke the Login Agent runtime resource. -> check the Control Room to see if the icon of Blue Prism RR has changed. (Login Agent Service uses the same name as Blue Prism runtime resource).
3. Assuming the Blue Prism session has been scheduled in advance for the Login process tied to Blue Prism runtime resource, the Application Server is supposed to be able to run the the schedule which, now, is going to run by Login Agent RR
4. The Login Agent RR will log in and then replaced by the Blue Prism RR. -> check this from the Control Room.
In a nutshell, the Login RR and BP RR is in a seesaw relation and the Login Agent Service monitors the Windows Login status and control the Login Agent RR accordingly.
Hope this video clip help: https://youtu.be/a0Af7sq5pSY
Reagrds
HongJoo Choi
diane.sanzone
Level 7
Hi Sushma,
I believe this is a known issue in many of the older releases of Blue Prism. If you run the "logout" process and the runtime resource is already logged out, it will kill the agent on the machine until you reboot.  BP suggested either upgrading and installing the new login agent package or altering your logout process to first confirm the machine is logged in and, if not, simply end.
I don't have the link to where this is on the BP portal, but I'm sure if you google it you can find it.  Which release are you on?
Diane Sanzone
Hi Diane,
I am using 7.0 version of blue prism. I have reinstalled the login agent for 7.0 v still facing same issue. after logout process BP runtime resource is not working
Sushma Rajolli
Hi Sushma,
My apologies for using incorrect terminology. The issue is with the logout process. I believe version 7.0 is susceptible to this bug based on the release notes I found here:
https://portal.blueprism.com/customer-support/support-center#/path/Upgrade-Expansion/Upgrade/1579866972/What-are-the-known-issues-in-Blue-Prism-Version-6-10-releases.htm
I have taken a snippet of the applicable section here - it seems that it wasn't resolved until 7.1.
If this doesn't resolve your issue, I'd recommend a case with BP support.
Good luck!
Diane Sanzone
Hi Diane,
We are facing similar issue in one of our client setup. In UAT environment everything is working fine however on production with same configuration when we run logout on runtime resource, the status changes to missing connection and as a result we are unable to run login process. We have BP 6.7.3. Making these changes to Logout process will logout the user and not cause missing connection/connection lost stage? Or am I looking at wrong solution for my problem?
BR,
Rahul Bansal
Rahul Bansal
Hi, Rahul,
It's been a while now since I've had this, but it seems odd that 2 environments with identical configurations would have different results. That said, this is a relatively minor change and it was presented by BP support, so if your change control process isn't prohibitively difficult, I would think it worthwhile that you implement the work around.  It can't make things worse, and if it does you can always roll back.
Good luck!
Diane Sanzone
michaeloneil
Hi @Sushma Rajolli
Have you check your security policy configurations? The security polices should be set up to allow login agent to start up after the logout action is complete. (see policy settings below). I once had to set up machines to work with login agent where the client didnt want to change the security policies the machines and resulted in the machine being offline if you use logout on it. The only way to use this if the policies are not set correctly is to lock the screen instead of logout.
Michael ONeil
Technical Lead developer
NTTData
#MVP
