29-08-19 05:09 PM
30-08-19 12:08 AM
Hello Sivakumar
As you have mentioned that the resources go offline after the Login Agent performs its function successfully, is the scheduled process working fine after that? If not, you can look into the logs and see what are the errors being generated and share them with the Blue Prism Support team for further investigation
Also, I would also suggest you to login to the Application Server at the same time and check what is the status of Runtime Resource at that time.
Karan Sareen
30-08-19 06:43 AM
30-08-19 07:51 AM
30-08-19 08:18 AM
11-09-19 04:42 PM
12-09-19 02:48 PM
12-09-19 02:49 PM
17-09-19 08:21 AM
23-09-19 04:17 AM
