Mainframe Automation - How to maximize the Emulator session window once lauched
Arun_KumarPalan
I am working on a Mainframe Automation (IBM PCCOM API) use case where I am not able to maximize the Emulator window (because unable to spy the active session in win mode) which is open post launch activity. Can someone provide your thoughts / solutions to achieve this?
Arun
Arun Kumar Palanisamy
ManpreetKaur1
Level 8
Hi @Arun_KumarPalan,
Please try to spy the outer window of Emulator window using "Win32" mode. Once done, use a Navigate stage and select "Maximize" option to maximize the application.​ Please let me know if it doesn't work for you.
Manpreet Kaur
Manager
Deloitte
Thank you Manpreet. It worked.
Nanjunda Narasimhamurthy
Hi @ManpreetKaur1
when am trying to spy the outer window of mainframe it is directly converting into gridview mode which we can spy the region of the Mainframe screen. can some please help me out. how to spy the outer window of mainframe using blue prism
first when start spying the mainframe it showing me win32 mode as below
Once i click on the window, it directly converting itself into grid view mode without press Alt button to chnage the spying mode as below, can see the grid mode is coming from the window rather than from black screen
naveed_raza
Level 8
you have to create separate object, in application modeller you can select the windows and attach to the mainframe application then only it will work
you can't do windows action directly in mainframe application setup
we are also doing this, we have created separate object, attached to mainframe application
