Monitoring tools
tommar
Hello
The organization I work for want to have a way to track the performance of are RPA processes (e.g. track the runtime of processes to see if they start running slower then expected etc)
Does anyone know of any tools or features in blue prism that can help with this?
Thomas Marshall
5 REPLIES 5
ewilson
Hi @Thomas Marshall,
There's a standard integration with Splunk available on the Digital Exchange.
Is there a specific monitoring tool you're looking at?
No specific tool right now were looking for one to use right now.
I have a look into Splunk
Thank you for the help
Thomas Marshall
EmersonF
You can also search for Grafana, currently used and I have nothing to complain about.
Exemple: DashBoard Audit | Blue Prism Product
Emerson Ferreira
Sr Business Analyst
Avanade Brasil
Recife
+5581988869544
Sr Cons at Avanade Brazil
@Thomas Marshall,
If you leverage the Data Gateway feature of Blue Prism (depending on what version of BP you're on) you can export the session logs of Blue Prism to any number of locations. With that you could probably use whatever tool you want. You might have to write some custom hooks/code/dashboard in the tool to interpret the BP data, but it's doable.
Cheers,​
Thomas - take a look at Elasticsearch/Logstash/Kibana (ELK) too. Data Gateways is based on Logstash and as such fits nicely with Elastic (storage) and Kibana (dashboarding). You can also configure your processes to emit process-specific data too if desirable. Elastic also have a nice suite of 'beats' - small tools that sit on each machine transmitting all kinds of system monitoring data to ready-made dashboards.
John Carter
Professional Services
