Moving Elements from Object level to process level
Guys,
need some advice here. I have a big project that has a lot of dependencies and plan to move some items from object level to process level, somehow when I plan to export it in production is a bit heavy to take each object, select it and add it to the solution. As you know sometimes we call sub-process and sub-object from other sub-objects so this creates a big net of action/stages/objects etc.
I want to ask you if is an easier way to move things in order to have them at a process level, so the export would be a very easy to do?!
Thank you and have a great weekend!
Cohen
Romania
peterlacken
Level 7
Hi, there is no such out of the box refactoring help that you describe. You can copy paste object code to process code provided it doesn't have the object specific actions like 'Navigate'. I have a question....if you have already abstracted some logic used in the process down to the object, why would you want to lift it into the process? I have refactored plenty in the other direction, process to object, but not the reverse. Genuinely curious for the reasoning 🙂
PeterLacken
Ren Røros Intelligent Automation
[email protected]
http://www.rria.no
