Hi All,
Just wondering if you can help on this error I am receiving recently.....
Over the past week a process I have has started to play up and then displays the following:
Internal: Could not execute code stage because exception thrown by code stage. Word experienced an error trying to open the file. Try these suggestions. " Check the file permissions for the document or drive." "Make sure there is sufficient free memory and disk space." Open the file with the Text Recovery converter. (C:\Temp\...SEF906 etc...)
I have checked all disk space and Memory etc and all seems fine.
Any suggestions? I'm not sure if the VBO has an issue as its only recently started to happen.
Many Thanks
Tom
