NG Java script
20-06-15 04:18 PM
Hi
Has anyone managed to interact with what appears to be a NG script on a web site. Trying to get a new application operational and it appears that one of the menu options use this script to navigate.
Manually there are no key board shortcuts. The only way of using it is to click the drop down button then click on the menu option. You can't scroll down or type any key strokes ,press enter or anything.
In Blue Prism I can spy it as a HTML combo box and can click a button to drop out the list and even use a navigate stage with select item, which It does as it highlights the item. But won't progress from there. Sending a global key stroke of enter doesn't work. I've tried creating a region and setting a navigate stage to send a mouse click with no effect.
Looking at other web sites I see a navigate action has the option of invoke a javascript function. Has anyone used this and do you need to install java access bridge to use it?
0 REPLIES 0
