Need Application for Surface automation
NagendraA
Hi Team,   i am looking application for Surface automation, can you please suggest to me , where i will get surface automation application.   Regards, Nagendra
Sri_Krishna_Cha
Hi Nagendra, there is nothing like Surface Automation application. You need to use region editor (one of the editor modes) which is used for surface automation.  While you are spying, use Alt button for switching between editors.
Try the training apps in the SA training courses. But just about any application will do, the whole point of SA is that it is (almost) universally applicable. Font-smoothing has to be disabled for reading text, and things like gradient colours, scrolling, tables and truncated fields are common challenges.
