Not Able to Select DropDown
Neel1
Hi, i am trying to select the value in drop down as shown in attached snap. I tried following method but it is not working:   1. Tried sending value via GSKE. but it is not working when there is space between the words. 2. I tried to read the HTML code also, but that is also not giving any specfic information. 3. I tried select option available in botton side of navigation but still not able to select the drop down. with saying that, i also feel that may be i am not able to use the select option properly. 4. I  dont want to use surfac automation. Please can anyone guide on steps for using select item in Navigation stage or any other option to select the drop down.
IshaSingh
Hi Neel, Can you try padding the spaces in your words as   when sending the value via Global Send Keys? It would be worth a try, if you haven't found a solution already. Ex. ""Core CS"" Thanks, Isha
