Not able to run Process in Scheduler
25-07-16 10:42 AM
I've Blue Prism 5.0 setup on my laptop, and I have a process scheduled to run every morning at 11 AM as well. But the scheduled task would not run in the actual time also there are no error logs or session logs to identify that it ran or failed.
I'm sure there's no error with the process or the scheduling steps. I guess it has more to do with Blue Prism environment or some server services which needs to be enabled or so.
Does anyone of you faced this issue and have a resolution to the same?
Aniruddha
25-07-16 11:54 AM
The reason could be that your PC/resource is not set as a Public resource. For that, you need to run a script.
You can refer to the document at https://portal.blueprism.com/system/files/product/productpublic/4.2/Inf
for more details.
