Not all processes are starting via schedules
15-12-21 02:04 PM
Only up until recently, some of our processes (not all of them) fail to start via schedule, they remain in a pending state until manually started.
I checked the schedule logs and found this
I've also found that if that above error appears for 1 process and another is kicked off straight after, I see these errors
Has anyone ever come across this before?
Task: XXXXX - Session creation failed on resource 'SERVER1': Failed to create session on SERVER1- No reply from Resource PC |
Task: XXXXX - Session creation failed on resource 'SERVER1': SERVER1is too busy to run that process. |
16-12-21 04:27 PM
Well, you have two different errors here:
If you keep having issues, please get in touch with our support team by creating a ticket so we have one of our engineers work with you.
- Task: XXXXX - Session creation failed on resource 'SERVER1': Failed to create a session on SERVER1- No reply from Resource PC
- This is because the RR is losing connection or timeout. You will need to review why this is happening with your network team. Remember that BP needs a good connection with the RR; having a slow ping reply like more than 5 seconds is not good.
- Task: XXXXX - Session creation failed on resource 'SERVER1': SERVER1is too busy to run that process.
- This RR may have other processes running and need to wait until it is free. Also, if you create a Resource Pool, we have the following KB Article "How do I fix error "Resource Pool is too busy to run that process." when assigning tasks to Resources in the pool."
